Perform this procedure to view the remote Intermediate-System-Intermediate-System (IS-IS) interface counters.
  1. In the navigation pane, expand Configuration > Fabric.
  2. Select Stats Remote.
  3. Select the Interface Counters tab.
Interface Counters Field Descriptions
Use the data in the following table to use the Interface Counters tab.
Name
Description
Index
Shows a unique value identifying the IS-IS interface.
Level
Shows the type of circuit that discovered the interface counters. The point to point Hello PDU includes both Layer 1 and Layer 2, and IS from a single adjacency on point to point links, therefore combining counts on point to point links into one group.
AdjChanges
Shows the number of times an adjacency state change has occurred on this circuit.
InitFails
Shows the number of times initialization of this circuit has failed. This counts events such as PPP NCP failures. Failures to form an adjacency are counted by isisCircRejAdjs.
RejAdjs
Shows the number of times an adjacency has been rejected on this circuit.
IDFieldLenMismatches
Shows the number of times an IS-IS control PDU with an ID field length different to that for this system has been received.
MaxAreaAddrMismatches
Shows the number of times an IS-IS control PDU with a max area address field different to that for this system has been received.
AuthFails
Shows the number of times an IS-IS control PDU with the correct auth type has failed to pass authentication validation.
LANDesISChanges
Shows the number of times the Designated IS has changed on this circuit at this level. If the circuit is point to point, this count is zero.
